My dwg writer is saving as type ‘file’ with no dwg association. How do I write as dwg and can someone explain what causes this?
Thanks!
Set the output filename with extension .dwg. But l'm not sure what your mean.
13 votes
12 votes
11 votes
9 votes
7 votes
6 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
