I cannot see 3d multipatch data in Graphics
totree30
Forum|alt.badge.img+3
캡처Hello!
I have Esri 3d Mulitpatch data as a shapefile, and I tried to see the 3d data on Graphics, but I can see nothing. Also I tried to extrude 3d objects from 2d multipatch, and I insert correct height value, but nothing has changed. Could you tell me how can I solve this issue? I tried to change the coordinate system and I've done several times, but only coordinate system is changed and still cannot see the 3d.
birgit
Forum|alt.badge.img+16
  • December 18, 2023
Can you try putting the AppearanceRemover transformer after you reader and report back? Another option is that the front and the back of the multipatch are flipped, this can cause the multipatch to be rendered incorrectly.
totree30
  • December 20, 2023
thank you for your help! the problem was beacause of the coordinate system haha sorry for my mistake
