Since they use different parameter settings, can we have both of them established in the same FME Form? I am having issues while trying to establish the connections.
Hi @jaygrg111_​ thanks for your question, I believe you should be able to! Perhaps I need more details, but all of your web connections can be found under Tools > FME Options > Web Connections and you can set up separate connections for each if you wanted to. If you could share with us what you have tried so far, we could give a more in depth answer. See our tutorials regarding SharePoint connectors for more information:
Hi @Evie Lapalme​  Thank you for your response. I was able to establish the Multitenant web connection on my Desktop outlined in this link (https://community.safe.com/s/article/How-to-Create-a-SharePoint-Web-Connection-for-FME-Form-Multitenant#SharePointOnlineConnector). But I am getting the following error on FME Server:- "Test Failed: Authorization and token retrieval was successful by refreshing the token using 'Refresh Token Parameters' failed. Requested to update access token failed. HTTP Error: HTTP/1.1 401 Unauthorized".
The Sharepoint admin has already given me the consent - but still I am getting the above. Let me know if know if I can explain it better in any way. Any suggestions/help is highly appreciated. Thank you so much.
Ah perhaps this article should help: https://community.safe.com/s/article/Troubleshooting-SharePoint-Web-Connections-and-Services#unauthorized
Otherwise, @jaygrg111_​  I would suggest creating a case with us so that a support specialist can help you with this error!
