HI. I would like to ask FME team about how to see the contents of storage inside of FME flow, and how to manage/delete the storage (temporal storage or primary disk) of FME flows. I would like to reduce unnecessary payment/charges, so please kindly let me know. Thank you.
Hi @4dlink​ , are you referring to FME Flow or FME Flow Hosted? The differences can be found on our Feature Comparison page.
FME Flow (FME Server) is self-managed. Therefore, the available resources are dependent on your system configuration and hardware: Host System Sizing. However, storage is unlikely to affect cost in this deployment option.
Whereas, FME Flow hosted (FME Cloud) has a console to monitor resources: Instance Monitoring
For either scenario, FME Flow has automated options for cleaning up logs and files: Configuring System Cleanup Settings
Hope that helps!
