How to connect fme server to the network drive?
elmido13
Forum|alt.badge.img+3
Best answer by david_r
You'll have to make sure that the services are running as a domain user with appropriate network permissions, see https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Running_FME_Server_Engines_Under_Different_Account.htm
On Windows, the default service account has no access to any network resource.
hkingsbury
Forum|alt.badge.img+54
  • April 21, 2023
Are you meaning through the Resources page? The Windows user account that runs FME needs to have appropriate access to that location
  • April 21, 2023
