Is it possible to export floor plan data from Smallworld in CAD format using FME ?
  • February 10, 2022
  • 11 views
  • February 10, 2022
@udhaya​ Yes you should be able to export your floor plans to CAD. But you will need the appropriate FME and Smallworld configuration. First have a look at the article: FME and Smallworld Configuration Options.
Then, for how to work with FME Desktop and Smallworld data, you can walk through our training: FME Desktop for Smallworld Training Course Resources
