Put hatches in polygon and write to DXF
  • March 2, 2022
  • 30 views
I have created a random polygon (in EPSG: 4647) and now I want to put hatches inside of it via DWGStyler. They should be depicted in an angle of 45° and as lines - this works. Between the lines, there has to be a distance of 2 meter and this is where I got stuck. I've tried to achieve this via Pattern Scale in the DWGStyler and by setting "autocad_hatch_pattern_space" to 2 by using an attributecreator, but this doesn't seem to work properly.
Best answer by daveatsafe
Hi @phil7g​,
Please try using fill pattern ANSI31 with a Pattern Scale of 16. This seems to give a 45 degree pattern with a 2m spacing.
Screen Shot 2022-03-02 at 3.06.17 PM
daveatsafe
Forum|alt.badge.img+19
  • March 2, 2022
Hi @phil7g​,
