Importing a python module into FME SERVER
Hello everyone,
It’s my first time on the forum, my excuses if im not following the requiered procedures.
So to the explanation and question :
I know that the readers for Shapefile and DBF interprets « null » numbers as 0, so i’ve writen a script using python3.8 that uses an external library to change number types to strings.
It works very well on the FME Desktop 2018.0 instance but when i try to upload it to the FME Server ( resources/engine/plugins/python/) wich is on a Linux ( Ubuntu 20) and using the docker images provided by Safe i have the following error when i launch a job that uses a pythoncaller that uses the « dbf » library :
-         Python Exception <ImportError>: dynamic module does not define module export function (PyInit_dbf)
After some research the cause it’s that the engine doesnt find the directory where the module is installed.
Any ideas ? Tips ?
Thank you.
Be the first to reply!
