Hello, i'm trying to use seaborn library (python) in fme. When i want to import seaborn in a PythonCaller, i've this message : "Python Exception <ModuleNotFoundError>: No module named 'tkinter'".
Is there a way to have this python module in FME?
virtualcitymatt
Forum|alt.badge.img+35
You need to copy the python modules into Documents>FME>Plugins>Python
​FME should then find them when using the PythonCaller
  • April 30, 2021
This works great for simpler modules, but for larger packages with dependencies it might be easier to install them using the pip package manager, see https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Installing-Python-Packages.htm
  • May 3, 2021
In fact, it's the way i installed seaborn, pandas and other modules. But for tkinter, it doesn't work. Tkinter comes normally bundled with Python.
johnglick
  • August 19, 2021
i have a similar problem, did you figure out a solution?
johnglick
  • August 19, 2021
So turns out I just needed to tell the library I was using (matplotlib in this case) to not use tkinter. https://openwritings.net/pg/matplotlib/using-matplotlib-without-installing-tkinter-gui-framework
mathiku
Forum|alt.badge.img+7
  • August 26, 2021
I have the same problem when calling WhiteboxTools. Thing is that tkinter is inside the plugins folder.
johnglick
  • August 26, 2021
In my case I had to include this line: matplotlib.use('Agg') # Bypass the need to install Tkinter GUI framework.
Seems like FME will not use Tkinter even if it’s installed.
Instead of viewing the output using Tkinter I passed a png to a feature so I could view it in fme workbench.
mathiku
  • August 27, 2021
Thanks. That doesn't work for me though.
mathiku
  • August 30, 2021
@david_r​  Would you care to elaborate on what to do with Tkinter when it still throws no module after pip installation?
  • August 30, 2021
Using pip together with the Python interpreter installed with FME does not always work 100%, especially for FME before 2020 (in my experience) and/or if the packages are particularly complex in their installation.
Perhaps the best (or, at least easiest) solution is to install a stand-alone Python interpreter (e.g. from python.org) and to install all the third-party modules there. You can then point FME to this interpreter, see https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Python-Compatibility.htm
kailinatsafe
Forum|alt.badge.img+21
@david_r​ , I think you're right regarding using a custom Python interpreter (one that comes with tkinter).
