I was looking into connecting directly SQL server to arcgis and ran into issues when using the update feature in the writer's field, can this be fixed? as when I have it on update I get number of errors, I have found a work around that issue by setting up insert and truncate features instead of update but this is taking too long, any idea why I the update feature is causing issues? and can it be fixed?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
