I'm not fully understanding how to reference the attributes. I've been attempting, but my lack of familiarity with json is preventing me from adding the attributes properly. Can you give me an example? I've read the docs and the help, and additional json guidance, but I'm new to working with json. Can I parse the whole thing into a grid using only the HTTPcaller and the JSONflattener with the proper attributes? I think my challenge is the syntax for exposing attributes.
For example, this query is GET JOB DATA for a single job. At the top level, there are connections and nodes, and a literal string that is the key and value for the name of the job. I've been able to get some pieces flowing, but I can see my the ignorance that is limiting me is fully understanding json formatting (I'm trying :D !) and that would help me understand better the relationships within the document.
I sincerely appreciate the guidance. Would you provide perhaps an example of the syntax I would use to expose one or two of the keys within the Jsonflattener given the example_json? I'll crack the flattener back open and read more about exposing attributes.
Thank you very much for your response. 😀
