Does Dissolver Dissolve separated polygons?
klingdom
Forum|alt.badge.img+5
We have short Workspace to update attributes and geometry (polygons) and added the Dissolver transformer, but when run the polygons are not Dissolved. When run we get more tract in the output than when in. Cannot see why this is not striate forward. Thx
WorkspaceDissolver
nielsgerrits
Forum|alt.badge.img+52
Are the incoming features aggregates?
nielsgerrits
You can test this with an aggregatefilter. The dissolver is set to deaggregate aggregates.
od10
Forum|alt.badge.img+4
  • May 9, 2023
Hi @klingdom​ ,
I've had this before, if the polygons are not spatially aligned or overlapping, the dissolver will actually deaggregate them and split them into seperate polygons. Rather annoying, take a look at the aggregator transformer instead.
klingdom
  • May 9, 2023
Thx. These are aggregates.
klingdom
  • May 9, 2023
od10 wrote:
Hi @klingdom​ ,
Many thx od10. Thx. Aggregator does seem to work. Have to run a few more test.
