How to apply attribute alias to all features using the existing attribute name
Using the AttributeManager, i understand that i could create a new attribute_alias for each attribute i want to update. However, since there are hundreds of attributes and they all need to be named the same as the existing attribute name - except in TitleCase without underscores > I wonder if there is an easy way to do this?
Best answer by nielsgerrits
nielsgerrits wrote:
I would try:
  • Select one row using a sampler.
  • Explode attributes into features.
  • Use a tester to remove the features where _attr_name starts with fme_
  • Create attributes from _attr_name.
    • Name: @Value(_attr_name)_alias
    • Value: @Value(_attr_name)
  • Expose created features using import from feature cache.
  • Remove _attr_name,_attr_value
  • Merge the features into one feature using the Aggregator.
  • Merge this single feature with all the _alias features to the original data using a FeatureMerger where 1=1.
Attached workspace demonstrating this.
nielsgerrits
I would try:
nielsgerrits
  • July 12, 2023
nielsgerrits wrote:
I would try:
Thank you Niels that's really helpful
