Error with no excuse that makes sense
dewrightco
Forum|alt.badge.img+4
So I have a job that usually runs on my server but trying to troubleshoot it locally is giving a error that makes no sense as  all the scenarios are invalid.
The Login is validated in ArcCatalog 10.8.1, There is no ArcGIS Pro elements mentioned as this is a basic Geodatabase, and the log-file only shows these 4 lines.
Could not open the Enterprise Geodatabase. The error number from ArcObjects is'-2147216118'. The error message from ArcObjects is: {Bad login user}
Please ensure the connection parameters are correct (server=`mySQLServer', instance=`sde:sqlserver:mySQLServer', user=`GIS', password=`***', database=`GCSS', version=`dbo.DEFAULT')
It could have failed to open because it contains ArcGIS Pro-only features, for example Arcade expressions. If this is the case, please install ArcGIS Pro or Pro-compatible ArcGIS Server and 64-bit FME
A fatal error has occurred. Check the logfile above for details
Is it possible for FME Desktop to not see my 10.8.1 install so it can't reference the correct libraries?
rahulsharma
Forum|alt.badge.img+10
  • January 5, 2021
Hi @David Wright​
If you are sure that you do not have ArcGIS Pro arcade expression and the SDE connection is correct, it is possible that the issue may be related to an architecture mis-match.
ArcGIS Desktop 10.8.1 is a 32bit application and thus will require 32bit FME Desktop to check for ArcGIS Licensing.
Although, Esri has released a small utility to leverage 64bit capabilities which FME can also use. You can download the Esri 64bit Geoprocessing
Option 1 -- Use FME Desktop 32bit
Option 2 --Install Esri 64bit Geoprocessing
How to Download ArcGIS Desktop Background Geoprocessing (64bit) from MyEsri
  • Log in to MyEsri https://my.esri.com/
  • Click My Organizations --> Downloads
  • Under Download, Select ArcGIS Desktop Version you have installed
  • Download the Utility
  • Confirm that the package is installed. Go to ArcCatalog / ArcMap --> Help --> About
It may be required to restart the workbench.
dewrightco
  • January 5, 2021
rahulsharma wrote:
Hi @David Wright​
I don't think so; the log shows it checking out the "Advanced" license properly. And having both ArcGIS Pro 2.7 and ArcGIS Desktop 10.8.1 installed (with background GP installed as I use this a lot) should provide access to all possible DLLs/APIs that are needed.
An ArcGIS license is already checked out. The product checked out is 'Advanced'
Installed ArcGIS version is '10.8.1'
rahulsharma
  • January 5, 2021
Ok in this case this is definitely that case of reading a table that is only available in ArcGIS Pro.
Can you confirm this i.e. open the table in the workspace in ArcGIS Desktop 10.8.1?
Solution:
Force FME to use ArcGIS Pro license
In order to do this, please do the following
Open Workspace, Go to Workspace Parameters --> Scripting --> Python Compatability
Set the value to " Esri ArcGIS Python 3.6" as below
PythonCompatabiityNOTE: ArcGIS Pro 2.7 is officially supported in FME(Esri and FME compatibility) as it is released in Dec, the support will be added in the next minor release( It may still work in your current FME Desktop)
If you do not have any Python transformer and code in the workspace, please add a simple line in the Startup Python script dialog
import os
Run the workspace, confirm that ArcGIS Pro is license checked in the log file.
dewrightco
  • January 5, 2021
Solution:
import os
No, this GDB is never used in Pro; it's a enterprise application and the DB is only used in ArcGIS Server/ArcGIS Desktop. Yes, I have verified and ran my manual processes from ArcCatalog.
fmeuser_gc
Forum|alt.badge.img+8
  • April 7, 2021
@David Wright​ - I'm having the exact same issue with FME 2021 and Arcgis 10.8.1. The error doesn't make sense as I'm using only Arcgis desktop but not using Arcgis pro.
Were you able to resolve this issue?
Tagging @richardatsafe​ , @andreaatsafe
dewrightco
  • April 7, 2021
Hi _gc; I ended up rebuilding the connection documents used in the service connections. As the ESRI connection documents (.sde) are binary files there is not a good way to troubleshoot them.
rahulsharma
Hi @fmeuser_gc​
Can you confirm that the connection files can be opened in ArcCatalog or ArcMap application?
As suggested by @David Wright​, Can you try to recreate the *.sde files?
Can you confirm if you can read FileGeodatabase on the same machine? -- This test would clarify if the issue is with the connection file or FME is unable to check Esri license.
fmeuser_gc
  • April 7, 2021
@rahulsharma​ - It worked after I recreating SDE file. However these errors doesn't make sense as the earlier used SDE file was created in ArcGIS 10.8.1 as well.
dewrightco
  • May 18, 2021
rahulsharma wrote:
Hi @David Wright​
Still no sign of tips towards a real answer; and this is a major breaking issue.
rahulsharma
Hi @David Wright​
We can troubleshoot this via a support ticket. We have added a new option in FME Desktop 2021 which will handle this situation slightly better.
Go to Navigator --> Translation --> Esri ArcGIS Compatibility --> ArcGIS Pro
  • February 3, 2022
this worked in my case
