I have a very old file while contain contour lines. And then I obtained a new DEM from which I generated new contour lines. Visually I can see that between 2 files, the contour lines of the same elevation differ in distance and they differ from one elevation to another. Is there any way I can get a statistical result about max, min, mean between these files? And is it possible to visualize this?
How to compare old contour lines and new contour lines?
Best answer by redgeographics
Exactly what kind of statistics would you like? Min/max/mean elevation within the entire dataset?
To see the specific differences you can try a ChangeDetector (although my bet is that all contour lines will differ). As for visualisation, you can do that by picking 2 colors and showing both on a single map. An alternative visualisation is to pick the new DEM and create one from the old one, then create a grid, drape that over both DEM's and show the areas higher or lower with different colors.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
