FeatureWriter have encoding issues, PostGIS writes does not
  • April 4, 2023
  • 14 views
so_much_more
I am migrating data and are using a dynamic workflow. When I am using the PostGIS writer it run smoothly. But since i need post processing after writing to DB I sat up the FeatureWriter identical to the PG one. But the writer fail du some encoding issues on attributes with Nordic characters in their name
FeatureWriter (WriterFactory): POSTGIS writer: Internal Error: Failed to copy attribute 'FØRSTEDATAFANGSTDATO' to 'fã˜rstedatafangstdato'
I cant see this being about case sensitivity since there is no issues using the regular postgis writer.
Any ideas how this can be solved? Looks like a bug to me?
saraatsafe
Forum|alt.badge.img+9
  • April 6, 2023
Hi @so_much_more​, would you be able to confirm with us what version you're using? FME 2022.2+ should be able to handle this.
