Hi @spizam , you can just add new static attributes to a dynamic writer feature type on the User Attributes tab.
That was perfect, thanks @Takashi Iijima ! I was attempting a few different ways, and I thought I tried this exact method, but it ended up using all schemas within a GDB across all feature classes + the new attributes. Much appreciated.
As a follow up @Takashi Iijima , or others, I need to write this to Excel, or CSV as a last resort. When I try to add the new attributes, along with any additional attributes, it defaults to the original schema and removes anything I add. Is this a Excel Writer issue, or am I doing something wrong?
Nevermind, all sorted. I was copying/pasting attributes under User Attributes and the "Type" wasn't compatible with the Excel writer. It was just a matter of changing "char" or "double" to "auto" or something like that.
This is magic, Thanks @Takashi Iijima.
I spent all of yesterday trying to modify the schema feature to add a new attribute and then I found this article.
It all seems so simple once we have the answer.
