String Date/Time is not recognised.
  • November 13, 2020
  • 19 views
Greetings,
I am reading in Date/Time items in String format from an ESRI REST API.
I have a field uploaded with values (below):
1331249589000
1331249634000
1331249646000
1331249638000
FME cannot identify/transform the values??
Any suggestions or pointers would be appreciated.
Regards,
Clive
Best answer by ebygomm
It's a UNIX timestamp (time in milliseconds since epoch)
If you divide the value by 1000 and use %s as the input format in a DateTimeConverter you will be able to turn it into a more recognisable date
Forum|alt.badge.img+31
  • November 13, 2020
Thanks, much appreciated.
