How to add 2 metre elevation offset to Mean High Water Spring
gisgeek
Forum|alt.badge.img+9
I have a MHWS and along the MHWS line the elevation from the DEM varies. I want to locate the 2metre elevation point relative to the MHWS Line. Could you please suggest an approach that would work to identify this and convert to a lineimage
hkingsbury
Forum|alt.badge.img+54
  • January 19, 2023
Thats a really interesting problem. My initial thought would be:
  1. Add points every X meters along the MHWS (depends what resolution you want), make sure they're numbered in order
  2. Overlay these points on the DEM, you now know, for points every Xm what elevation it is on the DEM
  3. Then, using an AnchoredSnapper (segment snapping) snap those points to the +2 elevation
  4. Rebuild the line
One thing to be cautious of is how will this behave with (from the inland side) with very concave angles
gisgeek
  • January 25, 2023
  4. Rebuild the line
Should this work with just points and raster? I have converted line to points and extracted value from DEM to point for those point. When I try anchored snapper against the DEM it doesn't give me any values.
gisgeek
  • January 25, 2023
hkingsbury
  • January 25, 2023
I realise now I didnt add in one rather important step; convert the DEM to contours and use that to snap the points to - sorry!
gisgeek
  • January 25, 2023
Ok that makes sense. Thanks for your help
