problem with ExcelToPDFWriter
franco69
Hi I've tried to use The Excel To PDF Writer but i have problems
after some errors about phyton stuff i have installed pywin32 and pypiwin32
https://docs.safe.com/fme/2021.0/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Installing-Python-Packages.htm
fme.exe python -m pip install pywin32 --target C:\\Users\\<username>\\Documents\\FME\\Plugins\\Python
fme.exe python -m pip install pypiwin32 --target C:\\Users\\<username>\\Documents\\FME\\Plugins\\Python
fme.exe python -m pip list
it was successfully
but again an error message
ExcelToPDFWriter_ConvertPDF (PythonFactory): Splitting bulk features into individual features
Python Exception <ModuleNotFoundError>: No module named 'win32api'
Error executing string `"""
Converter from Excel (.xlsx) to PDF (.pdf).
This module depends on the following modules:
   - pywin32
To install open an elevated command prompt and enter: pip3 install <module_name>.
Heijmans
18-04-18
Rob Braggaar
Can somebody maybe help where is the error.....what i am doing wrong?
Cheers and Greetz Franco
daraghatsafe
Hi @franco69​ sorry to hear you are having trouble with this issue, have you taken a look at this post? It may be helpful.
franco69
  • July 21, 2022
I've installed the phyton stuff right and copied the two .dll files correctly
but always the same error.......I'm not the phyton guru but it would be very nice if i yould test this transformers for an important task or is another possibility to convert excel sheets to pdf in the meantime in the new 2022 release?
here is my error message:
- pywin32
Heijmans
18-04-18
Rob Braggaar
import win32com.client
import fme
import fmeobjects
def main(feature):
logger = fmeobjects.FMELogFile()
input = str(feature.getAttribute('filepath'))
sheets = str(feature.getAttribute('sheets'))
sheets = sheets.split(',')
for idx in range(len(sheets)):
sheets[idx] = int(sheets[idx])
def convert(in_wb_path, out_pdf_path):
""" Converts input file to output pdf """
print('Input: ', in_wb_path, '\\nOutput:', out_pdf_path)
excelHandler = win32com.client.Dispatch("Excel.Application")
excelHandler.Visible = 0 # do not show Excel to the user
print('Starting conversion...')
wb = excelHandler.Workbooks.Open(in_wb_path, ReadOnly=1)
print('Workbook opened...')
# Excel sheets to export to the pdf destination.
ws_index_list = sheets
logger.logMessageString('Exporting sheets: {}'.format(str(sheets)))
print('Selecting worksheets {}...'.format(ws_index_list))
wb.Sheets(ws_index_list).Select() # WorkSheets
print('Worksheets opened...')
wb.ActiveSheet.ExportAsFixedFormat(0, out_pdf_path)
print('Done.')
# process wrap up
# close the workbook
excelHandler.Workbooks.Close()
# quit the Excel process
excelHandler.Application.Quit()
convert(input, input.rstrip('.xlsx') + '.pdf')'
Factory proxy not initialized
ExcelToPDFWriter_ConvertPDF (PythonFactory): PythonFactory failed to process feature
ExcelToPDFWriter_ConvertPDF (PythonFactory): A fatal error has occurred. Check the logfile above for details
Excel Reader: Closing dataset 'D:\\Projekte\\R796_Excel\\JULY_OP\\BGU\\PA7\\08_Labor\\x_Probedaten\\Probenlisten\\PA7_BK-Lager_Münnerstadt_Probenliste_gesamt_20220624.xlsx'...
Styles created: 303
Translation FAILED with 6 error(s) and 0 warning(s) (0 feature(s) output)
FME Session Duration: 3.3 seconds. (CPU: 0.7s user, 0.5s system)
END - ProcessID: 2284, peak process memory usage: 100972 kB, current process memory usage: 76128 kB
Program Terminating
Translation FAILED.
