Link pairs of points within a tolerance cluster
I have a set of points, and I wanna build lines between pairs of points whenever their separating distance is within a specified tolerance for example [3,4] meters
Best answer by nielsgerrits
One way to do this is to use the NeighborFinder with candidates only. Sample workspace attached.
nielsgerrits
Forum|alt.badge.img+54
  • March 25, 2021
Problem solved, thank you very much
