Is there a big difference in the rastermosaicker v5 and v7
  • March 10, 2023
  • 9 views
koenvdw
Hi
I just updated my FME 2021 to 2022.
I opened a workbench to make jp2000's from geotiff tiles.
We use this wb very often.
When I open this wb in FME 2022 I can update the clipper and rastermosaicker transformers.
When I run the wb I get an error that some geotiff tiles have 3 raster bands and some have 4 rasterbands.
I used rasterselector to select the first 3 bands followed with the rasterbandkeeper, but the wb gave the same error.
Then I used rasterselector to select the fourth band followed by the rasterbandremover. Then some tiles were outputted as rejected.
When I don't upgrade the clipper and the rastermosaicker everything works just fine...
Maybe it's because I just updated to a new version and my pc's need a couple of restarts for things to settle down...
I already purged the temp files.
hkingsbury
Forum|alt.badge.img+54
  • March 13, 2023
It does appear something has changed.
There is an idea to improve how version history is displayed, so worth giving this a vote -
https://community.safe.com/s/bridea/a0r4Q00000HbrkzQAB/making-transformer-version-history-available
