Update table or feature in AGOL with FME using JSON
  • September 1, 2020
  • 27 views
mr_fme
Forum|alt.badge.img+9
I am converting a JSON file to a table in arcgis online. This data needs to be updated every day. How do I update a table in arcgis online from external data (JSON)? I'm always getting errors ... Or at least delete and create a table again every time the workspace is set up.
WhatsApp Image 2020-09-01 at 16.08.34
thank´s
xilef
Forum|alt.badge.img+5
  • September 4, 2020
Hello, from the error message it seams like the data is missing the "OBJECTID_1" field that is required to perform an update or delete operation. If you want to update existing features in a layer or table, both the destination layer and incoming data must share a common ID attribute that will be used as the key to find the destination features and update their information. This field should be used in the feature type parameters as the update field.
mr_fme
  • September 4, 2020
Have you some example?
Thank´s
