Consume WebSocket stream from FME into Arcgis Geoevent
boubcher
Forum|alt.badge.img+11
Hello there
I have a published workspace that generates WebSocket stream, and I need to consume the data into ArcGIS geo event using input (subscribe to an external web socket for JSON )
I cannot figure out the URL structure that should be used to expose the WebSocket stream to an external app.
This web socket configuration imageand this is the Geovevent configuration. Note: I need the correct URL to put in the (remote server websoket) filed
rahulsharma
Forum|alt.badge.img+10
  • February 1, 2023
resegura
  • May 3, 2023
Hi @boubcher​
Were you able to get any answers for the websocket configuration?
