Hello there
is there a way we could generate random number grouped by feature type
the actual transformer does not have this option
Thanks
You can always put the RandomNumberGenerator in a custom transformer and configure it to do group by.
Added workspace demonstrating this.
@nielsgerrits
Thanks for your help,
I am no getting the same option as your workspace when I right client on random transformer to convert to custom transformer
That is correct, by default there are no Parameters for a Custom Transformer. You have to configure this yourself:
This can also be done for Transformer Parameters in the Custom Transformer:
These paramaters are now added to the custom transformer.
@nielsgerrits
thanks so much working
27 votes
25 votes
22 votes
19 votes
15 votes
14 votes
10 votes
8 votes
5 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
