FME Desktop 2022.1: Why clicking the gear sign of a transformer gets the displayed table disappeared?
jamal
Forum|alt.badge.img+5
I couldn’t figure out if there is a way to keep the displayed table appearing when clicking the gear sign of a transformer as per the screenshot below
Clip_938Clip_939
Clip_940
j.botterill
Forum|alt.badge.img+39
  • July 27, 2022
Hi Jamal, I think you want to inspect each port of a transformer. Read up about how to use the 'feature caching' option when running workbench
caracadrian
Forum|alt.badge.img+23
  • July 27, 2022
I recommend using the standalone Data Inspector. Just click the last icon on the right of your Visual Preview window.
InkedrenditionDownloadVisual Preview displays what you select to display. In the first case it displays your Reader (Q table), when you click on a different transformer (AttributePivoter) it displays the data coming out of that, and so on.
jamal
  • July 28, 2022
What I wanted here is have this option without the need to launch the FME Data Inspector
Clip_949
jamal
  • July 28, 2022
