FME personnalize skins
philippeb
Forum|alt.badge.img+20
Is it possible to change the skins of FME 2016?
I installed FME 2016 and I would like to return to the classic skins (FME 2015 or 2014).
It is not ugly, but it is not my style.
It would be cool to have several skins for FME :
- FME in DOS
- FME dark
- FME pink
- FME comics
I like to program XML or JavaScript into a black background, I think my eyes would like it for FME too.
Thanks.
Best answer by mark_f
There was the possibility of changing the skin in earlier versions of Workbench and looking in FME 2015 it seemed to still exist.
See menu Tools > FME Options click Appearance
where the option to install a Theme. This option is missing in FME 2016 as is the <FME_Dir>\\res\\themes folder that existed in 2015. I'm guessing it is no longer possible even though the 2016 documentation still refers to it.
  • March 1, 2016
mark2atsafe
Forum|alt.badge.img+44
Yes, I think it was dropped for 2016. I've asked the docs team to remove the references to it from the help docs. Other than that, I don't think there's much I can suggest to the original question. I don't know why it was removed (probably just one of those things that I don't think anyone ever used) but you could contact our support team (safe.com/support) and someone would be able to ask the developers why and if there is any chance it would return.
fmelizard
Forum|alt.badge.img+18
  • November 10, 2016
where can i find theme for FME ?
I would like to use a dark skin too ...
thanks
milo89
Forum|alt.badge.img+16
  • July 4, 2024
@mark2atsafe Was it ever discovered why they dropped it or still best to ask support?
mark2atsafe
  • July 4, 2024
milo89 wrote:
mark2atsafe wrote:
I think it was just too much effort to keep functional and very few people were actually using it. But that was 8 years ago. It might (or might not) be easier to achieve now. If you want that functionality again, you could always add it to the Ideas on this site - or check if it’s there already - and add some comments about why it would be helpful to you.
The product managers do review all of the Ideas, so it would at least be a start to put the idea in their head.
milo89
  • July 5, 2024
Thanks @mark2atsafe.
I raised the idea but it was recently merged into an idea that was quite different. Unfortunately not likely to get the same traction in the new merged idea.
