Is there a way to give the end user more than one option for the fme app uploaded data;
lubna_najeh
Hi All,
Is there a way to give the end user more than one option of the data he wants to attach in the fme server app?
For example, I want to have 2 options (Feature class, and shape file) as the input of my buffer app, How I can do that at the level of workbench and to be reflected to the app
In other words, can I have a multiple format reader in the workbench to be published into fme server?
Thanks in advance
Lubna
giosp
  • April 9, 2020
Hi @lubna_najeh
Have you tried to add two different reader (fgdb and shape) and set for each one a published parameter as optional?
lubna_najeh
Thank you @giosp I tried your suggestion but unfortunately it didn't work with me..
I found something which is a generic reader that accept any format, and it works fine with me
Best,
Lubna
jamal
Forum|alt.badge.img+5
  • April 12, 2020
Could you please provide screenshots on how this can be performed, Lubna?
