Token for Repository Access
  • December 31, 2024
  • 18 views
ax_pflegpeter
Forum|alt.badge.img+4
I created a token that is used in an HTTPCaller to download Workspaces from Flow via the Flow REST API. I granted the token only permission to access Repositories which worked fine but the problem is that as soon as a new repository is created, the initial permission is not extended for this new repos.
It seems that I either have to manually re-grant permissions everytime a new repository is created or grant “All Permissions”.
Is there any better option?
virtualcitymatt
Forum|alt.badge.img+35
That does seem like a bit of an oversight huh.
I would probably instead just create a web connection using the Admin user web connection. Just make sure only admin has access to the connection and repo where the workspace is.
Could that be an option for you?
