Hi, I am getting this error:
An error occurred while attempting to insert a row into the table ‘ABC’ using a cursor. The error number from ArcObjects is: '-2147217323'. The error message from ArcObjects is: {The cursor has been invalidated by an edit operation.}
I am experiencing an issue when trying to insert features into a feature class stored in an enterprise geodatabase. Specifically, I am both reading from and writing to the same dataset. I haven't encountered this problem before, but it began after I set the Feature Operations to "Upsert" while updating existing records and inserting new records that are not yet present in the database. I suspect that performing inserts and updates simultaneously may be causing a disruption with the cursor. I also attempted to use the Feature holder, but I received the same error. This disruption is affecting the automated process. Does anyone know what might be causing this error or how to fix it? I would greatly appreciate any assistance!
Thank you!
