BUG? Dis/Enabling transformers within bookmarks - FME 2024
  • April 2, 2025
  • 58 views
agelfert
Working in FME Workbench  (Form ) 2024.2.
When I disable all transformers inside a Bookmark (via right-click => “Disable all Objects in Bookmark”) and then enable them again using the same method, those transformers are still all listed as ‘Disabled’ in the Navigator. FME “knows” they are enabled because the right-click now allows me to “disable” them. But this seems like a bug.
How do you disable a disabled transformer?!
Not a functionality issue but kinda annoying, as I’m upgrading a bunch of large workbenches and like to turn things on/off for testing.
Forum|alt.badge.img+53
  • April 11, 2025
If you haven’t already, and are able to reliably reproduce this, best to open a support ticket. That will ensure it gets passed through to the correct team to review.
