What are valid values for a custom schema's data types in a dynamic wokspace?
  • March 27, 2025
  • 29 views
dsign-world
The website Dynamic Workflows: Destination Schema is Derived from a Lookup Table > Creating a Table-Based Schema > Geometry Type tells me that valid values for the `geometry_type` column are the values from the `fme_type` format attribute. It provides the full list of values under this link. The link is incorrect. This is the list of FME internal data types. These are NOT valid values from the `fme_type` format attribute and these are NOT values from the `geometry_type` column in the screenshot above in the tutorial.
Where is the correct list of values for the `geometry_type` column or the `fme_type` attribute?
AliAtSafe
Forum|alt.badge.img+19
  • April 2, 2025
Hello, ​@dsign-world.
Thank you for posting to the community forums. Thanks for sharing your experience with one of our articles - we appreciate it. Information about the valid combinations of fme_type and fme_geometry for features can be found here: FME Geometry Model. We have updated the article to include this doc. Hope this helps!
Best.
