Neighborfinder multiple candidates and calculate average distance
pabloolivaresm
I need to find the average distance of 25 nearest neighbours in a point layer. I have tried with Neighborfinder set to 25 number of neighbours to find and generate a list, then a ListExploder to expose the list, but I don't know how to group the 25 neighbours to calculate the average distance of these 25 neighbours to the base point
Im gettin this of ListExploder: idRecord it’s the ID of points.
Any ideas for grouping the 25 neighbours to calculate the average distance?
Thanks you all.
Best answer by geomancer
Instead of exploding the list, use a ListSummer to summarize the distances, and divide the sum by the number of candidates (use a ListElementCounter to verify the number of candidates, or simply use 25).
geomancer
Forum|alt.badge.img+48
  • March 13, 2025
pabloolivaresm
Thanks ​@geomancer, it’s works!
geomancer
  • March 17, 2025
You're welcome, thanks for the feedback and the 'Best Answer’!
