Hi! I could use a hand.
I'm running an FME workspace that downloads data from ArcGIS Online using 4 HTTPCallers and a Web Connection. The workflow works fine in FME Form 2024, but when I publish and run it in FME Flow 2024.1, it fails.
Setup:
- Using a Web Connection to authenticate (ArcGIS Online).
- The Web Connection exists in FME Server and is assigned to my user.
- The Web Connection is correctly assigned in FME Server.
Does anyone have experience with this issue? Could it be related to permissions, token handling, or FME Server settings?
Any suggestions would be greatly appreciated!
