ESRI Geodatabase Reader Not Working
  • February 27, 2025
  • 60 views
asali
I am not able to use the ESRI GDB reader, as I am not able to open a layer from my database.
So I created a reader reading a layer from GDB and then later this layer was removed from GDB, now I am not able to use the GDB reader at all, even if I open a new workbench and press the three dots button in the parameters of the reader, used to select the “Tables” , it gives me a message “Failed to retrieve feature types” “Layer not found”, but the layer mentioned in the error message is the old layer which is already removed from the GDB. And i didnt even got a chance to select a layer. What to do? Please do help.
saraatsafe
Forum|alt.badge.img+9
  • March 3, 2025
Hi ​@asali, would you be able to open a support case so that we can take a closer look with you? Please include some screenshots as well as your build and version of FME.
