Access domain network resource (folder) from outside the domain
  • February 18, 2025
  • 0 replies
  • 17 views
janroggisch11
Participant
Hi everybody,
Has anyone had success with accessing a file share on a domain-joined server from an FME Flow instance hosted on a VM that is not domain-joined? If so, what mechanism did you use to put this in place?
Thanks for any thoughts and ideas!
Be the first to reply!
