Hello everyone,
I am trying to use the change detector to compare changes from the current input data compared with previous runs to filter out Features that have not changed in order to save some processing time.
In order to do that I create a hash using the CRCCalculator and save that away. With each new run those hashes are compared agains the previously saved hashes. The ChangeDetector gives me pause though.
For some tables the ChangeDetector identifies changes where there are none. Whats more is, when I rerun the ChangeDetector, second time around the results are as expected without changing anything in the workspace. Maybe anyone has some insight into what could be going on here?
1st time running identifies updated features that arent updated at all
2nd time running without changing anything: different (this time correct) results
