FMEFlow affected by CVE-2024-50379 and CVE-2024-56337
  • January 9, 2025
  • 4 replies
  • 221 views
kihen
Participant
Hi! I am getting a warning that FMEFlow is affected by CVE-2024-56337. I am running FME Flow 2023.1.1
Is this correct?
Is there a fix or are these CVE not applicable?
Best regards
/Kim
Best answer by zoe.forbes
Hi Kim,
I can confirm FME Flow is not affected by CVE-2024-56337, CVE-2024-50379 or CVE-2025-24813, since these vulnerabilities require write access to the default servlet which Flow doesn’t provide.
Sorry it took so long for you to get a response to this!
Zoe
Edit: Since this response, we’ve published an article on CVE-2025-24813’s impact on FME.
zoe.forbes
  • March 19, 2025
Hi Kim,
Zoe
todd_davis
Forum|alt.badge.img+22
  • March 19, 2025
@zoeforbes Is there going to be any article regarding CVE-2025-24813, which we can point clients to?
My indication yesterday to clients was that the default servlet is readonly, but I also said you guys would be looking into it to confirm.
zoe.forbes
  • March 19, 2025
Hi ​@todd_davis, there isn’t an article yet but I’ve let the Knowledge Base team know it’s been requested. They do however tend to only create articles for vulnerabilities affecting FME, so one may not be published.
If clients remain concerned, please feel free to submit ticket with them CC’d. Unfortunately, there isn’t much more information we can provide beyond confirming that the vulnerabilities I mentioned above don’t affect Flow as the default servlet is read-only.
todd_davis
  • March 19, 2025
Thanks ​@zoe.forbes. I have sent relevant clients a screenshot of your initial response, so hopefully that will suffice.
