Converting List Attributes from 3D CityDB to CityGML Using FME
  • November 28, 2024
  • 44 views
joeluhlin
I am working with CityGML data and using FME to process and transform buildings from a 3DCityDB into CityGML output. I know I can use the 3DCityDBImporter/Exporter for this but I would like to create a custom FME script for more control.
I am trying to transform attributes from the 3DCityDB into a format suitable for CityGML output, specifically list attributes like citygml_function{}, citygml_function{}.codeSpace and citygml_usage{}, citygml_usage{}.codeSpace. These attributes are stored as strings with values separated by --/\--, and the corresponding URLs (codeSpace) are also in a similar delimited format.
I attatch one building with these attributes in csv format as an example.
The end result should be like this feature (building):
Have anyone done something similar as this? Im not very used to working with lists. Would appreciate the help, thanks in advance!
joeluhlin
  • November 29, 2024
I solved it with a PythonCaller. Way easier to handle the data there.
Here is the Python code if anyone is facing the same problem:
import fme
import fmeobjects
    def __init__(self):
        pass
    def input(self, feature):
        function = feature.getAttribute('function')
        function_codespace = feature.getAttribute('function_codespace')
        usage = feature.getAttribute('usage')
        usage_codespace = feature.getAttribute('usage_codespace')
        function_list = function.split('--/\\--')
        function_codespace_list = function_codespace.split('--/\\--')
        usage_list = usage.split('--/\\--')
        usage_codespace_list = usage_codespace.split('--/\\--')
        for i, value in enumerate(function_list):
            if value:
                feature.setAttribute(f'citygml_function{{{i}}}', value)
        for i, value in enumerate(function_codespace_list):
            if value:
                feature.setAttribute(f'citygml_function{{{i}}}.codeSpace', value)
        for i, value in enumerate(usage_list):
            if value:
                feature.setAttribute(f'citygml_usage{{{i}}}', value)
        for i, value in enumerate(usage_codespace_list):
            if value:
                feature.setAttribute(f'citygml_usage{{{i}}}.codeSpace', value)
        self.pyoutput(feature)
    def close(self):
        pass
    def process_group(self):
        pass
    def has_support_for(self, support_type):
        if support_type == fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM:
            return False
        return False
