Hi there,
I have connected to a Sharepoint Excel file in my workbench. I am able to read the rows and values when inspecting the Excel.
However, when I connect the Sharepoint Excel reader into any transformer, I get the error below:
Exception ignored in: <finalize object at 0x13bf76a0; dead>
Traceback (most recent call last):
File "weakref.py", line 590, in __call__
File "C:\Program Files\FME\python\urllib3\connectionpool.py", line 1135, in _close_pool_connections
conn.close()
File "http\client.py", line 1020, in close
File "socket.py", line 505, in close
File "ssl.py", line 1311, in _real_close
File "socket.py", line 499, in _real_close
OSError: [WinError 10093] Either the application has not called WSAStartup, or WSAStartup failed
Exception ignored in: <finalize object at 0x13bf7cc0; dead>
conn.close()
Error running translation.
When I try open the Python file linked the error log, it does not open (not sure if this is expected or not).
I have tried getting around this by first creating a copy of the Sharepoint Excel with no luck.
Any pointers on how to fix this? Thanks
