Getting UTF8 error from SharePointOnlineConnector
  • October 23, 2024
  • 15 views
sg2171
I built a flow where an Excel spread sheet updates a snowflake data table. The spreadsheet in located in a SharePoint documents library. To get the flow to run on an online FME server I had to put in a SharePointOnlineConnector. When I run the flow, I keep on getting “Could not decode contents of ‘jjjjj.xlsx’ as ‘utf8’. I’m running FME workbench 2022.2 at the present time. Any ideas on how to clear this error would be greatly appreciated.
Not a known issue to me, but it is also possible to read a file directly from sharepoint using the FeatureReader, which might be a workaround if that route does not returns the same error:
