Snowflake JDBC KeyPair failing
  • October 18, 2024
  • 52 views
weetak
i manage to set up ODBC with KeyPair but FME's JDBC connector with KeyPair is failing.
Google the issue and it points to this solution : https://stackoverflow.com/questions/70303334/secretkeyfactory-not-available-error-in-snowflake-jdbc
how do i actually implement it in FME JDBC connector?
https://docs.snowflake.com/en/developer-guide/jdbc/jdbc-configure#privatekey-property-in-connection-properties
Configuring the JDBC Driver | Snowflake Documentation
It mention about using BouncyCastle API . How do I actually enter this part of the code in FME JDBC connector?
steveatsafe
Forum|alt.badge.img+12
  • March 10, 2025
@weetak On the JDBC side, I’ve made some tweaks to the “Connecting to Snowflake using Keypair Authentication” that should address the bouncy castle configuration.
FME already ships bouncy castle libraries but they are not enabled without making use of an environment variable called JAVA_TOOL_OPTIONS.
setx JAVA_TOOL_OPTIONS -Dnet.snowflake.jdbc.enableBouncyCastle=true -m
The above example is set in the command window and will set a system wide environment variable. For more details, see the aforementioned article.
