line on line overlay
  • September 6, 2024
  • 5 replies
  • 120 views
hiyhelg
Dear FME community.
I hoop you will help me with the question I have. It seems simple question, but I could not solve it. I want to find out overlapping pipelines in the same dataset with different owners. I want to have list of the piplines who overlap with each other and who have different owners.
I used line on overlay transformer but I could not get what the result I wanted.
 Any help is apricated and thank you in advance
Best answer by bwn
In LineOnLineOverlayer set in Attribute Accumulation
  • List Name: OWNER
  • Selected Attributes: OWNER
Send the output of this to ListHistogrammer.  Create Histogram for List: OWNER
Send the output of ListHistogrammer to Tester:  If _histogram{1}.value Attribute Has a Value =  Where a line segment that has at least 1 different OWNER.
mot_fme
  • September 6, 2024
Can you show us the data / what is not working? Would be great to understand more through an example and hopefully we can help.
veschwab
Forum|alt.badge.img+13
  • September 6, 2024
It depends a little on how exactly your lines are overlapping, if they are intersecting or exactly laying on each other or are in close proximity to each other but it looks like they are overlapping.
You can try to use the SpatialRelator transformer and use your dataset as both the Requestor and Supplier.
  • Use "Requestor OGC-Touches Supplier" or "Requestor OGC-Intersects Supplier" or both to test
  • And most importantly choose an ID attribute in your dataset in the “Attribute(s) that Must Differ” so that the same line doesn’t compare itself.
bwn
Forum|alt.badge.img+26
  • September 6, 2024
  • List Name: OWNER
hiyhelg
  • September 10, 2024
  • List Name: OWNER
Thank you for your replay, it  seems a logic answer however the lastpart i have understood it yet.
This what I have done, Still I have not got the result I want. Can you please look at it
Thank you for help!!
bwn
@hiyhelg , to be able to review, need to see the Transformer Parameter settings.
In FME, you can show this in a Transformer Pop-Out by selecting the Transformer, then pressing Ctrl-Shift-K
The correct Transformers are used.  The reason for no results is either
  • Transformer Parameters not quite set correctly; or
  • There are no overlaps between Lines with different owners, possibly because they are not exactly snapped to each other (Consider using a Snapper if this is the case)
Sample Data
Input to LineOnLineOverlayer , ListHistogrammer, Tester
Outputs the common line segment that has more than 1 Owner
