Flow REST API Upload curl
  • September 3, 2024
  • 342 views
pflegpet
I try to upload a file to the FME Flow Shared Resource Folder via the Flow REST API. When I use Postman the request works as expected but I need to send the request in a command prompt with curl. Of course, first I tried to use the curl that can be generated in Postman but it always returns the error “curl: (26) Failed to open/read local data from file/application.
Here are the paramters for the working upload in Postman:
Postman generates the following curl:
curl --location 'https://fmeflow/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/Test' --header 'Authorization: fmetoken token=1234' --form 'file=@"/C:/Users/e059231a/Downloads/test_upload.txt"'
I already tried to remove the quotes from the filename and to replace the slashes with double backslashes but still get the mentioned error.
Best answer by dylan.at.safe
Hi @pflegpet,
I tested this on a Windows machine and initially encountered the same error you did. It appears that the Postman cURL code snippet is formatted for Unix-like operating systems.
I was able to successfully upload a text file using the formatting below:
Working URL Format
curl --location "https://myfmeflow.com/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/Dylan_Testing" --header "Authorization: fmetoken token=12345" --form "file=@C:/Users/dylan/Documents/FME Training/test_upload.txt"
dylan.at.safe
Forum|alt.badge.img+7
  • September 3, 2024
Hi @pflegpet,
Working URL Format
pflegpet
  • September 4, 2024
@dylan.at.safe,
Thank you! The curl command is now working for me as well. Had to replace the single quotes with double quotes.
