duplicate attributes on value-ranges
loldedub
I have a dataset with attributes where in two columns the start and end of a range (postalcode)
is it possible to duplicate the attributes with the missing postalcodes?
example:
range tels me:
from 7595AM  to 7595AP
there are 2 postalcodes missing. 7595AN and 7595AO.
from this attribute i would like to duplicate it to 4 attributes for each of the seperate postalcodes.
thanx in advance.
i am using FME Form 2024.1
Best answer by hkingsbury
Firstly, thanks to ChatGPT for helping with this - credit where credit is due!
The below python code will return a feature with an attribute new_code containing each of the missing codes between the specified start and end ones. In you python caller, make sure you expose new_code
import fme
import fmeobjects
    def __init__(self):
        pass
    def has_support_for(self, support_type: int):
        return support_type == fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM
    def increment_code(self, code):
        # Split the code into numeric and alphabetic parts
        numeric_part = int(code[:4])
        alpha_part = code[4:]
        # Convert alpha part to number
        alpha_number = (ord(alpha_part[0]) - ord('A')) * 26 + (ord(alpha_part[1]) - ord('A'))
        # Increment alpha number
        alpha_number += 1
        # If alpha number exceeds the range, reset and increment numeric part
        if alpha_number >= 26 * 26:
            alpha_number = 0
            numeric_part += 1
        # Convert back to code
        new_alpha_part = chr(alpha_number // 26 + ord('A')) + chr(alpha_number % 26 + ord('A'))
        return f"{numeric_part:04d}{new_alpha_part}"
        start = feature.getAttribute('postcode_van')
        end = feature.getAttribute('postcode_tot')
        curr = self.increment_code(start)
        while curr != end:
            feature.setAttribute('new_code', curr)
            self.pyoutput(feature)
            curr = self.increment_code(curr)
    def close(self):
        pass
    def process_group(self):
        pass
  • August 14, 2024
import fme
import fmeobjects
    def __init__(self):
        pass
        alpha_number += 1
            alpha_number = 0
            numeric_part += 1
        while curr != end:
    def close(self):
        pass
        pass
bwn
Forum|alt.badge.img+26
  • August 15, 2024
Having done similar in FME, then I’ve used Cloner for this.
Steps would be:
  1. Convert the Postcode AlphaNumerics into Pure Numbers.   Effectively the form you have is that each “Number” is a Decimal Number 0-9 , or a Letter Number A-Z (26 Letter Numbers).   This 10+26 = A Base36 Number
  2. Convert the PostCode Base36 “Numbers” into Decimal Numbers (Base10) using BaseConvertor
  3. Use Cloner to create the extra intermediate features/rows based on the Difference between the Base10 postcode_tot_decimal number and the Base 10 postcode_vav_decimal number
  4. Use AttributeCreator to set each new Feature/Row to a “postcode_sequence” number being postcode_van_decimal + the Cloner Sequence Number
  5. Back convert the postcode_sequence Decimal Numbers (Base10) back to Base36 to get them back into Postcode Alphanumeric Format.
  6. ListBuilder to wrap it into a List (Grouping into Lists effectively dissolves the Features into special List Attributes horizontally on the Feature)
  7. Join the calculated Lists back into the Source Features with FeatureJoiner
*Edit*
Extra little Tester step to handle when an “Intermediate” Postcode has a 0-9 Number in either the 5th character or the 6th character, which is invalid.
loldedub
  • August 20, 2024
Thanks for the options.
I tried both of them.
in my proces within FME option 1 worked well.
i just had to implement de postcode_van en postcode_tot.
The second one keeps running and gave me an out of memory.
thanks again.
kind regards
Laurens
