Converting to Epoch Time?
  • August 13, 2024
  • 101 views
schulte.a
I am having trouble getting this converted to the right format. The times seem way off when I use the date time converter.
This was a time stamp that was in a response message to a REST call that I got. Would anyone know how to prep these values + set up the date time converter correctly?
“1722597785000” ← format of timestamp
Thank you!
debbiatsafe
Forum|alt.badge.img+20
  • August 14, 2024
Hello @schulte.a,
The timestamp is milliseconds since Unix Epoch. The %s and %Es flags in the DateTimeConverter represent seconds since Unix Epoch.
Divide the timestamp by 1000 before converting the timestamp in the DateTimeConverter. Doing this will result in 2024-08-02T11:23:05 from the sample timestamp and %Es as the input format.
