Two dynamic surfaces find volume cut fill calculation
jp12212
Hi, I was hoping to create a workbench that has a base surface and a target surface and finds the volume between the two, is there any way to do that with the below transformer ie. make the base a surface with elevation differentials?
Any suggestions appreciated!
Thank you.
Be the first to reply!
