How to prepare geometries for DonutBuilder?
limo
Hi all,
I have geometries (roofs) and I will use the transformer donutbuilder for further processing. The incoming polygons are all planar. The transformer “DonutBuilder” stopped with this rejection code:
INVALID_GEOMETRY_DEGENERATE
I was hoping to solve the problem with the “Geometry Validator” (fix degenerate or corrupt geometries). But all geometries were ok according to the validator.
How can I avoid this error?
Does anyone have an idea how I can solve this?
Forum|alt.badge.img+51
  • July 17, 2024
It could be an issue of a non area feature. After running the data through the GeometryValidator, try running it through a geometry filter to ensure that all you’re passing through are areas
limo
  • July 18, 2024
thanks @hkingsbury I think I got it!. The geometry types are all areas. But there was an area feature without geometry. After AreaCalculator I have used a tester to filter geometries with area = 0!
This works for me so far!
