is it possible to upload a file to the FME Flow shared resource folder through the Flow REST API? I tried to setup a POST request for https://fme.oebb.at/fmerest/v3/resources/connections/<resource>/filesys/<path> but get a 415 Unsupported Media Type Response. I used the following parameters in Postman:
In this example I want to upload the text file “test.txt” to the shared resource folder “Test”.
Is there a problem with the request, or is this the wrong approach for uploading a file via the REST API? The goal would be to provide a means for external applications to upload files that are then processed by FME Flow. Thank you for your help!
