Alternative to "Near (analysis)" tool from ArcGIS Pro in FME
  • June 27, 2024
  • 77 views
repas4411
I have a line feature (electrical wire) and a polygon feature (containing buildings). I want to get the distance from the wire to all buildings, along with the parameters (angle etc.) when using the tool “near” in ArcGIS Pro.
Is there a way to do this in FME? Either with a similar tool, or maybe create some sort of connection and use that specific tool in FME.
Im working with FME workbench 2022.2
redgeographics
Forum|alt.badge.img+49
Sounds like the NeighborFinder is what you’re looking for.
